Bronze Member Username: Illwill577Post Number: 81 Registered: Jan-06 | my friend looking for an amp thatll push his 15" l7 wire @ 2ohm. its jus one l7 they are 1000rms and 2000 peak watts. any suggestions. his budget is not very high so as low as u can go but the recomended rms and what will get the sub bumping |
Bronze Member Username: Robman0079Post Number: 19 Registered: Jun-06 | this will do http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14926 |
Bronze Member Username: Robman0079Post Number: 21 Registered: Jun-06 | Actually i changed my mind this is cheaper http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368 |
Bronze Member Username: Robman0079Post Number: 23 Registered: Jun-06 | this is a little much but if he ever feels like adding another sub then get this beast(turn the gains down like halfway and itll be fine) http://cgi.ebay.com/AUDIOBAHN-A16000V-INTAKE-3200W-MONO-AMPLIFIER-CAR-AMP_W0QQit emZ9735307946QQcategoryZ64571QQrdZ1QQcmdZViewItem |
