Bev was working this morning (except PPV and XXX) now its not.
Is there any way to get it back by doing a manual key change? And since the Orasat bin has automatic autoroll, should I revert back to an earlier bin file? If so what is BEV's provider code? Any help would be greatly appreciated! Thanks!
as i promised, here you go..... while watching tv, keys in 6969 takes you to cas menu; for BEV and DN press blue key on remote to take you in.... the first 2 lines(1&2) for BEV. for example the index 00 01 to change it to the current keys, just goto index 00, press ok, use volume keys and channel keys to get to 0, hit ok, and just repeat the process til done then hit ok to save it. move to index 01 and do the same
