New member Username: NathulalPost Number: 1 Registered: May-06 | I have a Pansat 2700. I see two latest bins for it. The 148 which seems to have problem with autoroll, and the 271 release 05/26. What is the difference between them? Does the 271 have to autoroll bug as well? |
Silver Member Username: The_wank_artistPost Number: 561 Registered: Feb-06 | I think the 271 is the fix for the auto roll problem. You can try it and see what it's like. With it being only a couple days old there isn't much in the way of opinion yet. |
New member Username: AmounouFloride, Miami Laudedale lakes Post Number: 1 Registered: May-06 | i vant the new software pansat 2700a |
New member Username: JudsbugPost Number: 1 Registered: May-06 | can someone tel me the new bin to reset pansat 2700 - I keep getting wait for picture msg - A novice who would not mind step by step guide - Take care all |
New member Username: Jp5900Weyburn, Sask Post Number: 1 Registered: May-06 | need new download for a pansat 2700e |
New member Username: BubblyPost Number: 4 Registered: May-06 | what bin do I need for pantec 2500 ultra, please help me because I've gone on the websites and I can't find pantec anywhere. |
Silver Member Username: The_wank_artistPost Number: 582 Registered: Feb-06 | Judian and Jason, go to this post and follow the link for your model. https://www.ecoustics.com/electronics/forum/home-video/228421.html |
Silver Member Username: The_wank_artistPost Number: 583 Registered: Feb-06 | bubbly, This is from a post made by LK regarding clone bins. And I quote "The 275T bin works great for Pansat 2500 clones and ALL fortec Ultra's too...Tyler Durden is great. Its located at I slightly edited it for your enjoyment. |
New member Username: BubblyPost Number: 5 Registered: May-06 | Tyler,thx a million I was not sure if the pantec and pansat were the same receiver |
Silver Member Username: The_wank_artistPost Number: 585 Registered: Feb-06 | Pantecs are clones of Pansats, meaning cheaper knock offs. You have to be very careful that you load the clone bin (275T) so that it doesn't adversely affect the receiver. Loading authentic Pansat bins have been known to fry clones in the past. The clone bins have been labeled with the 'T' at they end of them...Hope that helps. |
