Any help/tips on reparing amps??
Username: Quig
Pittsburgh, Pa Us
Post Number: 102
i got 2 non working amps that i would like tot ry n repair, first volfenhag zx 7180... it powerers on 2 seconds later protect, 5 seconds later power, etc, no wires attached no rcas only groudn remot n power...
And then kicker dx700 old school amp, it powers on but dont put out anything, im guessing bad rca input.
basically is there any way i can find out if the rcas are fried or if an internal fuse is blown or if the channels are puting out power without powering the amp on. i have a ohm/ac/dc meter if that would be any use. any help would be great, thanks.
Username: Goatin
Ohio U.S.A
Post Number: 1251
http://www.bcae1.com/
Look at the first one on the right. it says amp repair tutorial
