HIFONICS BRUTUS BX12D2 12" 1,200 WATT DUAL VOICE COIL CAR SUBWOOFER, i bought 2 of these subs and i just need help in choosing a great amp and box for these prices, does not make a difference. here are the specs: * BX12D4 12" Subwoofer * Power Handling 600 W RMS * 1200W Peak * Dual 2 Ohm Voice Coil * Sealed Enclosure Size 2.0 Cu Ft * Ported Enclosure Size 3.0 Cu Ft * SPL = 93.39dB @ 2.83v * Illuminated Brutus Speaker Cone * Huge Double-Stack Magnet Assembly * 2.5-inch 4-Layer Hi-Temp Aluminum Voice-Coils * Woven Glass-Fiber Layered Composite Cone * Integrated One-Piece Spider- Tinsel Lead Design * White Chrome Steel Speaker Frame with Rubber Front Gasket * 1" Tall NBR Reinforced Rubber Surround * Rubber Magnet Boot * Ported Nickel Plated Back-Plate for Heat Dispersion * Nickel Plated Push & Insert Terminals * Nomex Spider-Assembly
