Gold Member Username: GoatinOhio U.S.A Post Number: 1148 Registered: Jan-06 | Would a 1000 watt rms 15" sub get louder than 2 500 RMS SQL sub's? I have 2 12" R's 500RMS a piece I want 1 15" ??? 1000RMS sub Any suggestions? Thanks, |
Silver Member Username: Extrmndor3Chicago, Ill Us Post Number: 902 Registered: Feb-06 | re audio sx, 13w7 , soundsplinter sr-s the supreme series, arsenals can take 1k rms, |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3586 Registered: Aug-05 | If they were the same subs.....the 2 12" subs would be louder.....b/c of more surface area. i would try a high powered like a STEREO INTEGRITY MAG!!!! haha alter or a Comp X or a Havoc or a DD 3515 or a Audioque HD or a Juggernaut |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3587 Registered: Aug-05 | the supreme series isn't really suited for car audio quirky SVC 4 ohm and it needs a huge box. |
Gold Member Username: GoatinOhio U.S.A Post Number: 1150 Registered: Jan-06 | so do you think I should just keep my R's ? I think I want 1 sub because I like subs to SLAM I dont really care for the rumble I just thought 1 15 would SLAM harder. |
Gold Member Username: GoatinOhio U.S.A Post Number: 1151 Registered: Jan-06 | Is the CompX 1000 RMS? I want to keep my system ~1000RMS. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3588 Registered: Aug-05 | rated at 1,600wRMS will take 2 i am sure. |
Silver Member Username: AlteraudiousaConcord Post Number: 813 Registered: Jan-06 | man, Muddy you took my line... Anyways, Stereo Integrity Mag !!!!! Either the 12 or the 15 will do well for you. |
Gold Member Username: GoatinOhio U.S.A Post Number: 1159 Registered: Jan-06 | Where could I find one of those? Stereo Integrity Mag |
Silver Member Username: AlteraudiousaConcord Post Number: 814 Registered: Jan-06 | If you like i'll get a price from Ben@showrides.net if he doesn't find you first. Send me your email Rave and i'll get a price for you. |
