Temp fix for cool*sat
Username: Boyce
Post Number: 115
8282
10: E8 70 B0 0A 8E 0A 3D C5
11: F3 59 C3 5F 1A DA 19 5C
20: 71 9C 60 71 04 C1 39 AE
21: 88 FF F0 5E D2 4C F3 FC
turn off autoroll
Username: Ikki
CA
Hi,
I'm new to coo!sat. I have the 4000 pro and usually load the bin file. How do I use this info you posted for temp fix?
Username: Boyce
Post Number: 131
you can use your remote press 8282, and in put the key, or go to http://forums.al*7bar.tk look for the new 4000 bin file come out this morning.
