Bronze Member Username: JohnfiacIl USA Post Number: 78 Registered: Mar-06 | I been searching around and cant find a .5 ohm stable amp....any1 have an idea who makes them? my subs measure to .9 ohms and it gets my 1 ohm amp hot and cuts it out.....do they even make them or is every1 lieing to me... can i link 2 amps togethor in anyway to get .5 ohm stable. |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1233 Registered: Oct-05 | wut kind of amp did u have that was gettin hot?? if you wired to a one ohm load with .9 ohm speakers, you should be fine. wut was the amp? |
Bronze Member Username: JohnfiacIl USA Post Number: 80 Registered: Mar-06 | Well i have a earthquake phd10000w\2 its rated for 5000watts rms at 2ohm's. It is a 1 ohm stable amp. If it is linked with another amp, it will be 2 ohm stable. It never even turns the Proctection light on when it does cut out, and i have to kill the remote and turn it back on to restart the amp....... Question.....Would my sounds sound the same at higher Ohms as the lower ohms although the watts are different? Or atleast will it still hit as hard... i dont think it does but then again this amp is screwy so i havnt really got to test that... at 2 ohms it sounded like $hit when i connected this to my subs(audiobahn immortal series 12' Quad 2 ohm VC's 2000rms each |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 631 Registered: Dec-05 | i do know an amp 1/2 ohm stable, lanzar optidrive 2000d, is a very nice amp and puts out 1950 at 1/2 ohm, is very cheap 330+ shipping, you can find it refurbished if you want on ebay |
Bronze Member Username: JohnfiacIl USA Post Number: 81 Registered: Mar-06 | Is Lanzar a well respected amp thouugh, i am looking for quality along with the 1\2ohm and i heard Lanzar is a fleamarket brand, but i have never actually heard a mono block from lanzar.. Another thing i should of noted.... i will need about 3500+ RMS to power my subs how i desire.. |
Silver Member Username: QcsfinestCharlotte, North Carolina Post Number: 186 Registered: Jun-05 | Ive heard of MMATS are good and they have two amps that are 1/2 ohm stable. The D2100.05 or the D3500.05 http://www.mmatsproaudio.com/classd.htm |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 266 Registered: Mar-06 | i heard audiobahn, thats probably why it sounded like sh!t, i dont recommend this but boss makes a .5 ohm stable amp, so they are out there |
Bronze Member Username: SqloverPost Number: 12 Registered: May-06 | Alphasonik makes an amp 0.5 stable. An excellent brand for amps! |
Silver Member Username: James_gTN Post Number: 496 Registered: Jul-05 | Look for some older US amps on eBay. We used to run them bridged at 0.5 ohms without any problems. If I remember correctly, they were 0.25 ohm stable in stereo. These amps were killer back in the day, but it's been many years ago. US 50, US 100, and US 200 come to mind. |
Bronze Member Username: Orion_hccaPost Number: 17 Registered: May-06 | the old orion HCCA series are stable at .5 ohms, im pretty sure the xtr series was too |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 189 Registered: Mar-06 | I know Logic makes a .5 ohm amp. I had an 800 watt Logic amp and it ran great but I haven't heard anyone else say anything about them so I am not sure about overall quality, but I liked it. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 637 Registered: Dec-05 | optidrive line is good quality |
Silver Member Username: Usask8er1Appleton, Wisconsin USA Post Number: 154 Registered: Jun-05 | Theres a guy in my town that has an orion 2500d wired down to .5 ohm and works great but im not sure if the amp is modified or not. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 643 Registered: Dec-05 | well, he will need some cooling fans |
