GO DOWN JUST ONCE TO GET TO SECOND PIN NUMBER AND ENTER 0000 (IF NOTHING HAPPENS ENTER 1668)
A NEW SCREEN APPEARS CALLED CAS SYSTEM.
GO DOWN TO AUTOROLL OPTION AND PRESS OK (If you don't see this option then skip this step but I recommend getting an upgrade)
GO DOWN TO DISHNET AUTOROLL AND TURN IT OFF USING YOUR LEFT/RIGHT ARROW BUTTONS
PRESS EXIT
GO DOWN TO NAGRAVISION-2 AND PRESS OK
PRESS THE DOWN BUTTON TWO TIMES. YOU ARE NOW IN THE KEY DATA BOX. YOU WILL ENTER A SERIES OF NUMBERS 0 - 9 AND LETTERS A - F THE NUMBERS ARE ENTERED USING THE NUMBER KEYS ON YOUR REMOTE CONTROL AND THE LETTERS ARE ENTERED USING THE BOTTOM SIX BUTTONS ON THE REMOTE CONTROL. AT THE BOTTOM OF THE TV SCREEN YOU WILL ALSO SEE A LEGEND SHOWING YOU WHICH BUTTONS ARE REPRESENTING THE LETTERS: A B C D E F
USING YOUR REMOTE CONTROL ENTER: E8 70 B0 0A 8E 0A 3D C5
PRESS THE DOWN BUTTON JUST ONCE
USING YOUR REMOTE CONTROL ENTER: F3 59 C3 5F 1A DA 19 5C THEN PRESS OK
PRESS THE UP BUTTON JUST ONCE TO ENTER THE KEY NUMBER BOX
PRESS THE RIGHT ARROW BUTTON TO CHANGE THE KEY NUMBER TO 01
PRESS THE DOWN BUTTON JUST ONCE. YOU ARE BACK IN THE KEY DATA SECTION
USING YOUR REMOTE CONTROL ENTER: 71 9C 60 71 04 C1 39 AE
USING YOUR REMOTE CONTROL ENTER: 88 FF F0 5E D2 4C F3 FC THEN PRESS OK
ON YOUR REMOTE CONTROL PRESS EXIT FOUR TIMES OR UNTIL YOU EXIT ALL THE MENUS.
YOUR FINISHED. IF YOU FOLLOWED THE INSTRUCTIONS CORRECTLY EVERYTHING SHOULD BE BACK UP AND RUNNING.
Keep in mind, I do not assist with this process over the phone or by email. If my instructions are not clear and concise enough for you to follow do not contact me for help! You are strictly on your own.
