Bronze Member Username: Jpio24Schaumburg, IL Post Number: 58 Registered: Mar-06 | 1998 pontiac bonneville. 4x6" factory in the front. 5.25" / 6.5" |
Silver Member Username: AlteraudiousaConcord Post Number: 793 Registered: Jan-06 | Depends on the space around the speaker mount. On my Alero I didn't have enough space around the speaker mounting place to place a 6.5. A 5.25 could work but would need a baffle to allow the basket to sit right. I wuold take it to a shop to have them look at it but i'm sure you could just depends on the work required for it. |
Bronze Member Username: DkchillinVermont Post Number: 73 Registered: Mar-05 | You can probably find the answer to pretty much any question here: http://www.bonnevilleclub.com/ As far as the speakers go though, you can almost always find or make adapter plates to change speaker sizes. I used premade Metra adapters in my '04 Grand Am to go from 4x6 to 5.25. The biggest issue will be where to mount the tweeters if your car doesn't have stock tweets. |
