Bronze Member Username: MzakcatPost Number: 28 Registered: Aug-05 | i have a decent list of channels with dish tp's i don't know what it means if it says "tp- 27s9" how can i scan a tp with the "s" in it, if it is just a "27" for example that works, this is more a locals question i guess? any ideas ? |
Bronze Member Username: MzakcatPost Number: 30 Registered: Aug-05 | i suppose lk is busy, this thread should really be directed to advanced users, maybe someone else can figure it out. |
Bronze Member Username: VinidominePost Number: 14 Registered: May-06 | Any channel showing a TP followed by "s" is spot beam and might not be available in your area. Source: In order to maximize space on the satellites and uplink as many stations as possible, DN has launched and put into service Spot Beam satellites. These allow a single transponder to be reused in tightly focused beams aimed at certain parts of the country instead of sending one channel nation wide. To see maps of the current spot beam satellites click here -> http://wvjw.info/dbs-beam/ . Vini. |
Bronze Member Username: MzakcatPost Number: 31 Registered: Aug-05 | thanx vini, very usefull, noway to manually add through gtools if spot beamed ?? |
Bronze Member Username: VinidominePost Number: 16 Registered: May-06 | Best solution is really running a "blind" scan - you get the real picture of whats available in your area, load it from the receiver into channel master and customize it from there. Then, load it back to your box. Vini. |
