Hey LK, Figured I'd share a funny story with you before you shut it down for the night. Posted the new keys a while ago, helped some people out. Decided to check my own set, 148 kept rolling. Couldn't get on to dsscentral for a new bin so I just removed auto roll and entered the keys manually. Spent the better part of an hour trying to get the f&%^in thing going before I realized I wrote down 79 instead of 71 as the first characters of the keys. Nice!
so Tyler can you tell me please exactly what keys I should be using for 00 and for 01? plus autorol must be off right? will those keys work only with BIN 148? or can I use 147 also? if not where can I get 148? thanks alot
Why my Pansat 2700a doesn't hold the new keys?When I use key procedure, I don't know how to save the keys when I am exiting to watch TV. I have a picture for one minute. I had BIN 147.
these keys work great..U people just need to learn how to use your own receivers and input them correctly...the bin doesn't matter regarding the keys!...keys are keys!
there is a topic thread "How to Input keys" that will tell U how to do it step by step for a 10 yr old!...inputting and saving keys is a moron task...its no harder than turning your computer off and on..
Tyler...U will burn out here and someday U will be called name like me...u lose patinece after awhile with all the stupidity...especially now I notice schools must be out now, cause many more people here during the day...79 will look like 71 after hours of talking to idiots who can't enter a simple set of numbers with their remotes!
LK, I've entered the Keys correctly into my pansat 2700A. It still says "Channel Scrambled." I am using bin 123 because it doesn't have an autoroll, what do I need to do?
Okay well the keys you posted up are the ones that I have put into the receiver. And still no channel information, "Scrambled Channel" , any suggestions? I got my keys off KeyMaster so I don't know if there is an error with their keys as well, but I'm gonna retry putting them in for the hell of it. If you have any other suggestions, like where I can get a correct bin, post direct link please, that would be neat. Thanks
