273t bin
Username: Donyahelwa
what is wrong with me.
I have tried bev keys
98F744AC5E07D9ED8AFF3B7E6571F94E
ACC2E13000A1C8540CB63162CA382FCB
nothing worked.
is there anything else to do. I have tried the new key for DN and still no pic. Anybody any thoughts?
should I replace the bin? and enter the new keys?
THX.
Username: The_wank_artist
Post Number: 447
98F744AC5E07D9ED
8AFF3B7E6571F94E
Just use these ones. The acc2e... ones are no good.
you may need to turn off your auto roll, if that bin has the function.
lots of threads on how to do that tonight.
Tylor thanks but
first I do have the autoroll and I did trun it off.
what about DN keys before I out those?
bunch of them out there!
Do u mean
BEV 0901
00 98F744AC5E07D9ED
8AFF3B7E6571F94E
sorry for that but you know not that good :-)
if so, what about o1 foe BEV?
thanks again.
Post Number: 452
00 98F744AC5E07D9ED
01 8AFF3B7E6571F94E
If you have two 00's and 01's, then do this....
00 98F744AC5E07D9ED
00 8AFF3B7E6571F94E
01 98F744AC5E07D9ED
01 8AFF3B7E6571F94E
good deal that is what I'm talking about.
I'll come back for thanks.
Username: Hotdagobabe
Post Number: 23
ok, im wiring a 6000hxc to my dual lnb dish?
i will add 2 lines from other lnb connections, take them to another sw21, then take that single lead to the receivers alternate input?
is this correct?
if i were to have a dishpro lnb with black dp on the back, which switch will work with 3500sd, the sw21 doesnt?? thanks
