Username: Canada115 Post Number: 3 Registered: May-06
Thursday, May 25, 2006 - 14:51 GMT What are the new Ariza 700 keys for Dishnetwork? All the other keyts mentioned for Fortec or Panasat dont seem to work. Anyone use Ariza?
Username: The_wank_artist Post Number: 475 Registered: Feb-06
Thursday, May 25, 2006 - 14:54 GMT all the keys are the same for all receivers.
Username: Nsalamoun Toronto,
Ontario
Post Number: 1 Registered: May-06
Thursday, May 25, 2006 - 19:38 GMT I got a new Ariza Xtreme Can anyone please help me and tell me how to enter the new key for dishnetwork to watch Echostar 3 on that receiver. I do not know how to get to nagra vision on that box. Please...
Username: Bertoro Toronto,
Ontario
Post Number: 49 Registered: Apr-05
Thursday, May 25, 2006 - 19:43 GMT tyler is rite...all receivers use the same keys
Ontario
Thursday, May 25, 2006 - 20:17 GMT Ferench, Thanks My problem is I can not get the nagra screen that enables me to enter the keys. Can you tell me how? Please and thank you.
Ontario
Post Number: 53 Registered: Apr-05
Thursday, May 25, 2006 - 20:24 GMT never done it before? menu, parental control. (input password)second pin select nagra...look 4 DN prov. id 0101, key 01 and then the nwe keys...save and exit, exit, exit till u get to tv
Username: Pm_man Post Number: 1 Registered: May-06
Friday, May 26, 2006 - 04:06 GMT can some help me with ariza xtreme keys in what row do i put them in 1,2,3,4? and can u be clear about it.
Username: Pm_man Post Number: 2 Registered: May-06
Friday, May 26, 2006 - 04:36 GMT can some help me with ariza xtreme keys in what row do i put them in 1,2,3,4? and can u be clear about it.
