PANSAT 2700A
Username: Skypatel
Hi
This is my 1st time posting. So please help.
I bought PANSAT 2700A receiver from store. I guess it is not programmed for DISNETWORK.
If I need to programm for DISHNETWORK to get all the PPV channel...can you please tell me how to do it. Do I need to install new software to program the receiver like new bin etc...if so can yo please tell me where and how can I download the software.
Thanks in advance
Username: Maple_leaf
Post Number: 1428
al7bar.t*k remove the *
Username: Al_bundy
Post Number: 13
1st off i am using the 146 bin the newer ones have a few bugs so i choose to use the 146.
1. Plug in the receiver, check and see that the switch on back is off.
2. Connect the null modem cable to the receiver and Com1 port of your computer. (Use Com2 if not Com1 is not available).
3. Load the Bin in the Downloader from the new created folder.
after it is loaded turn switch on reciever, as soon as you see the green light hit click "Download" button
4. wait until the "Download Completed!!" display. Watch the LED on the receiver, it should reboot itself, wait until the "ON" display.
5. You are done with the software update.
if you want to load a channel list leave cable plugged in .
turn reciever off from the front so clock shows and load channel list.
wait for reboot and switch off from rear then remove cable.
swtch on from rear and set your antenna settings
119= disqec 1 and 110(6,8) is disqec 2. if using a dish pro twin lnb
(no diseqc switch needed)
clear out of menu, hit channel 8282 and choose set default keys( or set them yourself under Nagra 2)exit out go to "user set up" set the time the date year .
when you set the time set the -4:00 for east coast time.
if no channel list then
6. go to menu antenna settings scroll down the list of sats to echo 7(119) click "ok a check mark should appear next to the highlighted sat.
and then scroll to diseqc settings set echo7(119) to 1
hit exit.
scroll to echo 6,8(110) and set it to diseqc 2 hit exit.
exit out to antenna menu scroll down to blind scan choose your sat
(i scan echo 6,8=110 first).
**if you have a dish pro lnb choose "vertical" under the polarity,**
If Legacy leave it as all
then go to scan choose "all" hit ok.
it will scan the sat let it go to 100 % then do the same for echo 7(119).
exit out after scan go to user set up ,set the time, the day the year. hit ok exit out to tv on the remote hit the SAT button scroll to "echostar package' hit ok hit ok go watch tv.
Username: Al_bundy
Post Number: 14
also try ***.future-fta.info/forum/index.php
***=www
Username: The_wank_artist
Post Number: 421
Al, I too was using the 146 bin but it crapped out on my about a week ago so I went to the 148.
Is your 146 still running.
Username: Skypatel
Thanks al bundy
But where do I get all the software to load the bin...also where do I get 146 bin and software to load that
Post Number: 427
Read Maples post, remove the * and replace with .
or try dsscentral*net. Register first, then search for your receivers files.
And I'd go with the 148, as it has an auto update tp function.
Username: Tdoalamo
Hi,
I am a newbee for pansat 2700 also.
just flashing the bin to receiver, setup atena and sattelite dish
but I got 'UNLOCK' display on the screen 'Level' & 'quality'.
even I changed the direction of the dish but I never got 1% of the signal quality.
Please help me on this
I had an old direct TV with one LNB dish.
Thanks
Username: Roderick36
hi my pansat 2700a was working fine yesterday until about 5pm it started "TP Channel update (30%)" then "wait for picture(550%)" and no picture ever tuned in so what's the problem can anyone help i'm using bin x-87bl-2.70c-ver6.2 060511 my e-mail is roderickdockery1@aol.com
Username: Micklee11801
Post Number: 20
I have pansat 2700a using 146 bin. I did a factory reset and then scan all the chanels again. All the chanels came back including the Vu and adult chanels, everthing. please try and watch t.v.
