Bronze Member Username: Pinkpiper1
Lafollette,
TN
United States
Post Number: 18 Registered: Mar-06
Posted on Hi! I am trying to enter new keys but the F=EPG will not work on my remote. I have tried all the buttons on my remote but none are keying in F. I tried another remote from my other box and it will not work either. I have also tried finding something in archives. No luck I have a Fortec Ultra Please help, Thanks |
Bronze Member Username: Mzakcat
Post Number: 24 Registered: Aug-05
Posted on sat- button? fav- button? |
Lafollette,
TN
United States
Post Number: 19 Registered: Mar-06
Posted on Thank you for replying. No, I tried all buttons and non key in F. please help Thanks |
Post Number: 26 Registered: Aug-05
Posted on i'm not running a fortec, but you may have to do factory bin first then new bin, if f=epg worked before |
Lafollette,
TN
United States
Post Number: 20 Registered: Mar-06
Posted on Thanks zak. I have the 274 bin. Maybe that's the prob. Anyone know? Thanks |
