New pansat BIN available!
Username: Me2eternity
new bin available for download at http://www.future-fta.info/forum/showthread.php?t=23699
I just tried it and it works on my pansat 3500.
X-05BL_060511_350eubx_epg_api.zip
Username: 7inooo
Post Number: 11
whats a bin and how do i change it???
if you have a problem entering the code manually just save that file and do the transfer. since you have a pansat 3500 just save it on your sd card and load it from there it's much easier
Username: 7inooo
Post Number: 12
i have 2500
Username: Vinidomine
Post Number: 9
haneen - what receiver model?
NOTE: its not the same procedure for all models.
Vini.
Post Number: 7
go to this post then
http://www.future-fta.info/forum/showthread.php?t=24916
Username: 7inooo
Post Number: 14
PANSET 2500 A
Username: Rockwall_sat
Rockwall, Texas
Does anyone have a bin file for pansat 2500a auto roll.
Post Number: 11
For Pansat 2500A instructions follow this link:
( http://www.future-fta.info/forum/showthread.php?t=10549 )
(if you get a logon screen, register a logon for yourself. - its free)
The link posted by Jonjon is to the actual bin file.
Vini
Username: Slimatic84
what is the new code for Pansat 2700a
