Pantec MS Ultra
Username: Ksolo101
Hey any one know what the CMPROJ Files are for and where can i get them,if i need them my friend says i do.. recently purchased the Pantec MS Ultra IDK exactly what BIN to use either but i can probably figure it out with some more reasearch ..please help!
Username: Grimreeper
Post Number: 90
most the pantecs are pansat2500 clones use the 274t bin its clone safe
Username: Lklives
Post Number: 2646
channel master files...
Username: Ksolo101
Post Number: 7
Thanks for the help
channel master huh....where can i get those files? i already downloaded the bin
(274t)
thanks again
Username: The_wank_artist
Post Number: 391
you can get it from here.
http://www.dsscentral*net/cgi-bin/hubblegram/CSUpload.cgi?database=pansat4.db&command=viewupload&id=n ull
replace the * with a .
Username: Ksolo101
Post Number: 8
Thanks man!
