Ariza 700 Keys?...help
Username: Canada115
What are the new Ariza 700 keys for Dishnetwork? All the other keyts mentioned for Fortec or Panasat dont seem to work. Anyone use Ariza?
Username: The_wank_artist
Post Number: 475
all the keys are the same for all receivers.
Username: Nsalamoun
Toronto, Ontario
I got a new Ariza Xtreme Can anyone please help me and tell me how to enter the new key for dishnetwork to watch Echostar 3 on that receiver. I do not know how to get to nagra vision on that box. Please...
Username: Bertoro
Toronto, Ontario Canada
Post Number: 49
tyler is rite...all receivers use the same keys
Username: Nsalamoun
Toronto, Ontario
Ferench, Thanks
My problem is I can not get the nagra screen that enables me to enter the keys. Can you tell me how? Please and thank you.
Username: Bertoro
Post Number: 53
never done it before?
menu, parental control. (input password)second pin
select nagra...look 4 DN prov. id 0101, key 01
and then the nwe keys...save and exit, exit, exit till u get to tv
Username: Pm_man
can some help me with ariza xtreme keys in what row do i put them in 1,2,3,4? and can u be clear about it.
Username: Pm_man
