274t bin not working
Username: Jhachimi
Post Number: 8
Hi,
Yesterday I lost all my channel. So I loaded the new bin 274t but it just keeps on rolling. The image never comes.
Anybody can help please
thank you
Username: Grimreeper
Post Number: 107
turn autoroll off and enter keys manualy
Username: Lklives
Post Number: 2725
Dishnet and Bell keys changed yesterday...the "rolling" is the autoroll inputting the new keys, if U would let it!...may take 1 hour and go to 1000%..
IF after 1 hour and it still rolling ,then disbale the autoroll...do NOT set the default key...EMU-OFF..or rename the satelites U are using with LNB's..then manually enter the keys
Username: Donsboat
I have 2500a with 2.74 on it have entered new key with outoroll off key stays OK but all channels are scrambled. new bin to manualy enter keys?
Username: Lklives
Post Number: 2733
change the channels..and/or reboot receiver off for 3-4 minutes..be patient!
Username: Jhachimi
Post Number: 9
Hi LK,
I put off the autoroll, but nothing works. So I put it back, and I got the PPV but not the regular staff. It's just rolls until 400 than it restarts. It was able to get half the code.
Should I just wait or there a way to keep my PPV and enter manually the key for the rest
And is it possible that 274t file I used was'nt good??
thanks
Username: Islander
Post Number: 16
pleas read (pansat 2500a clone help) this shoulp help
