New Keys for C@@lsat 5000??
Username: Jay235
I tried the following keys but they do not work
71 9c 60 71 04 c1 39 ae
88 ff f0 5e d2 4c f3 fc
thanks in advance
Username: Chevy_girl
BC Canada
Just tried same keys and nothing
Username: Aktarzaman
Same here nothing happened.
Username: Lklives
Post Number: 2710
Dishnet Keys 24 May 2330 hrs
Key 86(00):
E8 70 B0 0A 8E 0A 3D C5
F3 59 C3 5F 1A DA 19 5C
Key 96(01):
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC ...(Active)
Username: Georgemikhail
10 :E8 70 B0 0A 8E 0A 3D C5
11 :F3 59 C3 5F 1A DA 19 5C
20 :71 9C 60 71 04 C1 39 AE
21 :88 FF F0 5E D2 4C F3 FC
Try these keys and you will be OK. Good luck.
Username: Unmaddog
do i need to keep autoroll for echostar, BEV, EPG off or can i leave them on?
Cool- sat 4000pro
By the way guys these codes work great Thanks George Mikhail!
Username: Xcable
Rochester, NY USA
Charlie is sending corrupt keys again,If you enter new keys you must turn echo auto roll OFF for the time being.And only the last two lines need to be replaced.
Username: Dyno3742
How do I enter the keys on my Cool sat 5000? I just got it not too long ago?
Username: Navid
please i need key for file for skyview rx-500 and rx600 please help me here?
E that dude:
From remote go to setup ==>Installation==>Turn of the autoroll
Exit and save the change
From the remote punch 8282
Then try
Exit and save
This key works for me so far.
Username: Alfa9090
salam
pls your email
Username: Jay235
George,
They work.
Thanks a lot guy.
