Box....
Username: Bretzy1990
Springfield, Il U.S.
Post Number: 42
Do u think this would be an alright box for a 12'' Arsenal
http://www.subwoofertools.com/forum/ported-box.asp?Ew=16&Eh=16&Dia=6&Xmax=20.5&V d=.12&NumW=1&Vb=2.2&Fb=35&Qts=&Vas=&Fs=&CE=0
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 867
Seems like it is too deep.
Post Number: 43
How would i correct that because it cant be much taller or wider than that?
Username: Sw9152
Michigan
Post Number: 736
are you mounting the sub on the red or the yellow?
Post Number: 44
the red part
Post Number: 45
well im building 2 boxes so i could put them in the yellow and they would still fit.
Username: Sw9152
Michigan
Post Number: 737
the 12 arsenal needs about 11.25" dia cut out for the sub so how the design is now your sub wouldnt even fit. try to get at least one inch wider space. where are you putting the sub and in what car? idk you might just have to go sealed.
Username: Sw9152
Michigan
Post Number: 738
you have 2 arsenals?
Post Number: 46
yeah 2 arsenals in my trunk of a cuttlass supreme
Post Number: 48
if i built 2 boxes and put them in the yellow i could get them to easily fit in my trunk
Username: Sw9152
Michigan
Post Number: 740
what about one big box?
Post Number: 49
i like the idea of 2 and maybe just lay my amp in the middle of the 2 boxes..
Post Number: 50
do u think it would still sound alright if i put them into the yellow part of the box though?
Post Number: 51
alright i did it over so do u think that if i put the woofer in the red that it would be fine and sound alright.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=18&Eh=16&Dia=6&Xmax=20.5&V d=.13&NumW=1&Vb=2.0&Fb=35&Qts=&Vas=&Fs=&CE=0
Username: Sw9152
Michigan
Post Number: 743
^^^looks like that design will work a lot better.
