What is new Bin for Pansat 3500s and where do I get it
Username: Paulb
Username: Hurider
Hey bud, just follow this,
On your remote key pad enter "8282" to access the Cas System menu.
Go to the bottom and select "Autoroll Option".
Select "Dishnet Autoroll"..it will be "ON"...with your remote turn it "OFF".
Now press "Exit" ..this brings you back to the "Cas Menu"....select" Nagravision 2".
Make sure you have "DishNetwork" on top
Now manualy input these numbers.
Provider ID = 01 01
Key Number = 01
Key Data (Row 1) = 71 9C 60 71 04 C1 39 AE
Key Data (Row 2) = 88 FF F0 5E D2 4C F3 FC
The numbers are entered from your remote key pad and now for the letters.
Pause Key = A
Audio key = B
EPG Key = C
Last Key = D
Fav Key = E
Sat key = F
Press "OK" to save, get a brew and your old lady and watch "TV"....Good Luck and have a good week end....
HU Rider / Casper
Username: Hurider
The bin..I better learn how to read...sorry dude you will need to go to another site to get it.
I tried to attach it and it was to large ...or try doing a search...
Username: Me2eternity
Post Number: 10
go to www.future-fta.info
