New member Username: Melissa666Post Number: 1 Registered: May-06 | Do you know are these new codes work for lifetime ultra? Any advise? |
New member Username: Bazuka2020Post Number: 3 Registered: Oct-05 | yes they do |
New member Username: Melissa666Post Number: 2 Registered: May-06 | I changed the keys in Nagravision 1 - 00 and 01, but they are different now??? And it's not working... |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 436 Registered: May-06 | Melissa: Check the new keys posted today. https://www.ecoustics.com/electronics/forum/home-video/227788.html |
New member Username: Melissa666Post Number: 3 Registered: May-06 | YES!!! These are the keys that work for Lifetime ULTRA. My mistake was that I changed the short keys in Nagravision 1, not Nagravision 2!!! Thanks for your help!!! Dish Network: N 0101 00: E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C N 0101 01: 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC |
New member Username: Dyno3742Post Number: 2 Registered: May-06 | How do I enter keys into my Lifetime Ultra? im new at this. |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 463 Registered: May-06 | How to change the NAGRA2 Key codes (for Fortec Lifetime Ultra only) 1- Press Menu button on your remote control 2- Press right arrow key 2 times Channel Edit 3- Press down arrow key button 2 times, press OK (Code) enter 1010 4- Press the down arrow key to Set Default Key, click OK 5- Press the up arrow key to Nagravision click OK 6- On your top left you should see Nagravision-1...if not, then you've got the wrong BIN version. 7- Press right arrow key until you see Dish Network on top 8- Press the down arrow key once to Key Number 9- Press right arrow key 2 times the from Key Number 00 - 01 - 00 ( Now take notice that on your top left you should see Nagravision-2 now ) 10- Then press DOWN button key to change the keys manually on Key Number 00 11- Enter new Keycode, do the same procedure to enter the the keys on Key Number 01 https://www.ecoustics.com/electronics/forum/home-video/184799.html |
