Problems
Username: Master_mind
still new to this, only been at it for 4 days. as mention before i have a pansat 2500a clone. if i do a foctory reset, when i turn it on perantal control is blacked out,i can't select it. therefore i can't get to enter the keys for dn. oh i have 274 on my machine i did a blind search but only turn 10 channel none of which is dn. can some one help me on what to do. thanks
Username: Lklives
Post Number: 2680
MUST do a scan BEFORE U go to parental controls....then it will be hilighted!...and Bev is just about dead now due to Friday's ECM...
Username: Kjniceguy
Lethbridge, Alberta Canada
Post Number: 12
HI there..Probably a stupid question but here goes...if i do a Factory reset do i lose my current bin 2.73a ? And when i do a Blind Scan will SAT-62 be the scan of choice? or is there something else i am needing?
Username: Evadelparaiso
Puerto Rico
Post Number: 412
Kevn: If you do a factory reset do not lose your current bin, you only lose this bin if you jtag or run another firmware factory or another bin and BEV has a big problem. REad the another Thread. :-)
Username: Midou
ater flashing my 2500a pansat receiver, my receiver was shut down and i can't open it plz tell me how to do
Username: Midou
I downloaded the N2 files to my Pansat 2500a. It worked fine for 10 min, then shut down. How can I make it work again? Any suggestions please.
