Can you help? How and where to reset the key? I have 3500sd just got few days back and it is not working at this time. It was fine this eveing. Thanks, epor
Careful.. you could mess something up when the screen is not in any menu: ENTER 8282 with your remote. That should take you to the key screen. Enter new keys in the NAG 2 section and hit OK. Then exit out.
Here is a quick temp fix for 3500. Press " 8282 " to access the cas menu. then select autoroll option only select dishnet autoroll.....on....turn it off, then exit. this brings you back to the cas menu. select nagaravision 2 make sure you have dish network on top select 01 key code ( active key ) then input the new keys manually
71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC
pause key is A audio key is B epg key is C last key is D fav key is E sat key is F
Press OK to save, then exit and watch TV Good Luck
Hello.. Please help, Today at morning i was watching all my channels and every thing was fine, went fishing return back NO CHANNELS what so ever, what ever channel on any sattellite 110,119,61 is working keep giving WAIT FOR PICTURE xxx% andd i waited till 5000 but no good. Tried to restart the receiver no good, tried to reflash the bin file which is 143, and it was failing at 98% sometimes or 84 sometimes so we can say the failing percent is different. Tried to set it to default settings and try to reconfigure the sattellite and Blind scan same problem. The signal is perfect on all satellite and nothing been changed? Tried to use the Key provided by Dino Dino, and then rescan and check the channels same thing.. Please help I have no channels at all.
Depending on what bin you have Ted, you may need to turn off the auto roll. Sounds like your flashing of the bin 143 was failing so you'd still have whatever bin you had in there before. Just turn off autoroll via parental control and enter the new keys. These are the active ones and they are working.
My man Dini Dino You are a life saver, I thought the FTA ride was over for a second, but your post helped me! Dino Dino THANKS A MILLION!
Dino Dino's post -------------------------------------------------- Here is a quick temp fix for 3500. Press " 8282 " to access the cas menu. then select autoroll option only select dishnet autoroll.....on....turn it off, then exit. this brings you back to the cas menu. select nagaravision 2 make sure you have dish network on top select 01 key code ( active key ) then input the new keys manually
PLEASE HELP ME I HAVE A PANSAT 2300A AND I WANT TO CHANGE THE DISH NETWORK KEY FROM 00 to 01, SO HOW CAN I TURN THE AUTOROLL OFF, PLEASE TELL ME STEP by STEP* THANK YOU SO MUCH FOR YOUR HELP*
