Can anyone answer a simple question or are you going to argue all the time?
will it work to run 4 channel amp 2 2 12" subs with 2 voice coils? the subs are 4 omns a piece
Derek
Yes, that should work perfectly.
Louis
Yes it would work. My neighbour is running a jl audio sub with 2 voice coils off a 2 channel amp and it works nicely. You would be doing the same thing theoretically
