Help Making It Louder
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 366
so how can i make 2 10 re sx louder its loud but i no it can get way louder right now theres 2 10s in a 2.6cuft box tuned @ 32hz wit a 3 inch slot port in a firebird hatch an i no it can get way louder its runnin off a orion 2500d there gettin 1700w @ 2ohms under powerin an smaller box but that all i can fit in the bac is there anyway i can make dem louder if i could make a huge box i no they would b way loud but the biggest i can fit is 13h 25.5w an 17.75d
Username: Thomas_g
NM
Post Number: 671
Tune higher.
Username: Basshead86
Google is your Friend, FL
Post Number: 3533
1. Purchase a HO alternator.
2. Upgrade your battery.
3. Upgrade your Big 3.
4. Dynamat your Hatch.
5. Tune Higher.:-)
