What battery?
Username: Swisher
Marianna, FL
Post Number: 130
what size yellow top should i get with a 200amp alt
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2233
i don't think there are differend "sizes", just different models for different cars. check out Optima's web site.
Stockbridge, GA USA
Post Number: 2234
i don't think there are different "sizes", just different models for different cars. Check out Optima's web site.
Username: Swisher
Marianna, FL
Post Number: 135
they say thiers not one for a 98 eclipse
Username: Swisher
Marianna, FL
Post Number: 143
bump
Stockbridge, GA USA
Post Number: 2240
does the car have a odd battery or something?? as long as the compartment is large enough to hold the Optima, it'll work.
Username: Swisher
Marianna, FL
Post Number: 144
i know but i wont hurt the alt with one that too big?
Stockbridge, GA USA
Post Number: 2251
no. the yellow top isn't really that big compared to some of the other batteries out there either.
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 229
I used an Exide Maxima 900 deep cycle battery on my 97 eclipse. No problems at all. yellow top is da same as that one, just find the one that can fit on it and it should be the 70 ampere per hour.
Username: Cadillacdb
Houston , TX
Post Number: 703
im about to toss the yellowtops out the door and buy some kinetik monsters 2400 or maybe one 2400 and one 1400 or 1800 but i advise getting a kinetik... Kinetikaudio.com or you can search ebay for sellers
Username: Fandim
Reno, Nevada United State...
Post Number: 1024
Cadillac, why dont you like your yellowtops?
Username: B101
Queen City, NC USA
Post Number: 2898
Yelltops dont come close to Kinetiks... :-)
Im lookin at gettin 2 Kinetiks 2400s right now.. for under 250...
It will walk over a yellow... I think they said 3 yellows = 1 kinetik... Its just that much more amperage in a Kinetik..
