Temp Fix 3500
Username: Miatrouble
Here is a quick temp fix for 3500.
Press " 8282 " to access the cas menu.
then select autoroll option
only select dishnet autoroll.....on....turn it off, then exit. this brings you back to the cas menu.
select nagaravision 2
make sure you have dish network on top
select 01 key code ( active key )
then input the new keys manually
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
pause key is A
audio key is B
epg key is C
last key is D
fav key is E
sat key is F
Press OK to save, then exit and watch TV
Good Luck
Username: Hurider
Are you able to watch the HBO stations...I moved my dis earlyer so I might be getting another sat.
I can't get any of the Dish channels???
Yes all PPV, XXX, HBO's, SHOW.... all working.
Username: Frost167
hope this help people.
listen carefully very simple its a temporary fix until a new bin is ready.
if u have updated your pansat 3500sd with the latest bin {X-05BL_060511_350eubx_epg_api}
you are able to turn off all autoroll features.
trust me they are there look carefully and please read.
1 - go to menu
2 - press parental control
3 - input second pin with your code
4 - go to autoroll options
5 - turn all autoroll functions off then exit
6 - then go to user setup
7 - turn off tp autoupdate
8 - exit then go back to parental control
9 - repeat 3
10 - go to nagravision2 and enter
key0
E8 70 B0 0A 8E 0A 3D C5
F3 59 C3 5F 1A DA 19 5C
key1
if done correctly u should be watching tv on your pansat 3500sd in seconds. credit also goes to eva diaz and al bundy just took what they said
put it more in easy terms which can help thoes with the pansat 3500sd i hope this helps
