Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 148 Registered: Feb-06 | ive decided to order a havoc, so i made this box. its 5.8cuft tuned to 33hz. i still need to go ove some rough edges and cover it though. tell me what you think of it. |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 149 Registered: Feb-06 | sorry my pics suck ill go take some better ones. | |
Silver Member Username: NemenPost Number: 823 Registered: Dec-05 | is that the port on the top part? looks good though. | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 150 Registered: Feb-06 | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 151 Registered: Feb-06 | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 152 Registered: Feb-06 | these arent much better but its the best i can do. | |
Gold Member Username: RovinTrinidad & T... Post Number: 7934 Registered: Jul-05 | hmmm - a very different design there im trying 2 figure it out - is that box going against the back (what car) & port firing 4ward ?..... |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 153 Registered: Feb-06 | I just wanted to try something different, its going to be against the rear seats of my blazer. |
Silver Member Username: Matt12490Benicia, California USA Post Number: 911 Registered: May-05 | that does not look 5.8 cubes. just could be from your bad pictures (probably from a camera phone). what are the dimensions of it? | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 154 Registered: Feb-06 | sorry its 5.68186 cuft, the dimensions are..... Height- 21 Top depth- 17 Bottom depth- 24 width-18 |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2214 Registered: Feb-05 | i only get 3.78 cubes not taking away for port area or driver. | |
Silver Member Username: Matt12490Benicia, California USA Post Number: 921 Registered: May-05 | i got 3.41... how did you come up with 5.68 cubes?? | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 155 Registered: Feb-06 | width is 28 not 18 | |
Silver Member Username: Sw9152Michigan Post Number: 715 Registered: Feb-06 | you should make interchangable ports.
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 157 Registered: Feb-06 | whats a good amp for the havoc thats under 350$ | |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 160 Registered: Feb-06 | bump | |
Bronze Member Username: NorthomahaPost Number: 85 Registered: Mar-06 | i think a bx1500d hifonics would be a good choice at 1 ohm |
