Hi there, I have the new bin on VIEWSAT with autoroll and all. For some reason all the BEV channels are blank? I tried to update the code for BEV but without any prevail. Does anyone know if there are newer codes or if there is something else I need to do? Thanks
You don't need to do anything..bev has sent down counter measures..all are in the same boat until coders fix..aim to dish..all is well there right now.
Is there any temporary work around? Can I go back to bin v1010 for my Viewsat and hope that the Bev channels would work, or is it something that they have to fix? I currently have v1072 on my VIEWSAT (Platinum). Thanks
your out of luck for now..bev only works on plastic at the moment. like i said you could re aim your dish to 110,119 dishnet is still working fine right now.
I have been on BEV for about 2 weeks and want to switch to DN till the problems are resolved. I need help pointing my dish though. to get BEV i point my dish South. Where is DN? I live in western Ohio.
Hi there, thanks for the responses. I actually have two other dishes pointing to Echo 6,8 and have another pointing to Echo 9 (121W). I just didn't know what was going on with BEV with my other two dishes. I guess I'm going to have to wait it out. Too bad because there were cricket matches that were on BEV only.
