New member Username: Phoenix55555Post Number: 1 Registered: May-06 | Hi, I'am on BEV (Nimiq1). I'd like to change to DN. What is the name of the satellite I'd need to aim? I remember that I found it once when I was looking for Nimiq1, is not far from Nimiq1, isn't it? Thanks. |
Silver Member Username: The_wank_artistPost Number: 392 Registered: Feb-06 | http://www.lyngsat*com/packages/america.html Here is a list of birds and their degree position. There are a few DNs. |
Gold Member Username: Maple_leafPost Number: 1426 Registered: Apr-05 | Dish is 119 or 110 sats. |
Bronze Member Username: GrimreeperPost Number: 98 Registered: Feb-06 | twist your dish to the west slowly youll hit 119 or go a tad further for 110 |
Gold Member Username: Maple_leafPost Number: 1427 Registered: Apr-05 | grim it's just the other way around you hit 110 first then 119. |
New member Username: Phoenix55555Post Number: 2 Registered: May-06 | Thanks! Which one is better in your opinion (110 or 119)? I checked a little bit the channels on each of them and I have an ideea (ppv and HBO seems to be on both). |
New member Username: Pirate_petePost Number: 6 Registered: May-06 | Personable preference |
Silver Member Username: WoofyOntario Canada Post Number: 123 Registered: Feb-06 | If i had to choose between the 2, i would take 110, more channels and you will get the EPG. just preference...did you have a look at lyngsat? you can scroll through both 110,119 and make up your mind. just keep in mind there will be no EPG for 119. |
Silver Member Username: The_wank_artistPost Number: 395 Registered: Feb-06 | A whole whack of the locals were moved to 110 last month, if you're interested in watching Seinfeld 40 times a day. I'd go with 110 if I had to chose, though you do miss out on a few stations. Even better, just get another LNB and strap it to the other one and get both!!! |
Bronze Member Username: TariqicPost Number: 12 Registered: May-06 | When I twist my dish west, do I need to change the elevation? I am having a real hard time getting 119/110. Have no problems findin 91/82. THanx |
