SWITCHES
Username: Dellworkshop
Post Number: 10
i HAVE A C*SAT 4000 PRO, AND THE SWITCHES ARE HORRIBLE..PLS ASSIST WITH POSSIBLE GOOD QUALITY SWITCHES THAT I CAN FIND..SOMEONE SAID SADOUN IS A GOOD BRAND...PLS ASSIT
THANKS ALOT...
Username: Jmontana1
Post Number: 24
oops!
sadoun is a name of company that sells stuff on the net!
ask LK he knows everything!! idiott!
Post Number: 11
WHY DO YOU HAVE TO BE LIKE THAT !!!!!!!!!!!!!!!!
Username: Letmeon
Post Number: 18
I have 4 x 1 ARIZA switch, mounted outside in the elements. Had no problems with it.
Username: Woofy
Ontario Canada
Post Number: 115
You can buy pretty good cool sat switches for under 10bucks...or spend a 100..they will both blow if you treat them wrong. go cheap
