Kicker CVR ....Whos got em?
Username: Stnorris
Post Number: 66
i have 2 12" kicker cvrs.
I wanted to know who else has CVRS and tell me what your setup is...box, amp and Rms, head unit, wiring???
Just wondering what everyone else has hooked up to there CVRS.
Username: Stnorris
Post Number: 68
Anyone???
Username: Dustin3
Tigard, Or U.S.
Post Number: 1149
i have 2 12" cvr's. i have them in a custom box tuned to 32,hooked with a audiobahn a8002t, kenwood HU and wiring off of www.knukonceptz.com
Username: Moey
Sydney, NSW Australia
Post Number: 18
1 15" CVR in a sealed enclose, kicker kx400.1(465 RMS), 4-gauge wiring, pioneer HU
Username: Kickerandy
Vesta, MN America
Post Number: 71
1 12" CVR in a transmission line slot ported enclosure, tuned to 32hz, 4 gauge wiring, kicker kx400.1 mono amp, pioneer head unit.
Username: Imalik
Jackson, New Jersey Ocean
I have 2 12 4 ohm dvc cvr, I must they soud great but 1 of the coils went bad in each speaker, caused the amp to go into portect mode. Im going with th L5 now.
Username: Thomas_g
NM
Post Number: 553
I have 2 12" cvr's dual 4 ohm 1 in box w/ slot port tuned to 32hz and 1 in box w/slot port tuned to 35hz each with 2.20 cuft of airspace. 1 268 lanzar amp with not sure wut but a lil over 900rms with both bridged for 4 ohm load. Pioneer HU, and i think PA wiring kit 4gage. Its fu*kin loud! Hey stevo did u hook up ur cvrs yet?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1154
malik - dont go with the l5, u will be alot happier if u got a better amp and ran those cvr's correctly. the l5's are square which mean that It has a limited excursion, and suffers from increased stress points due to is shape.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1155
^^ which causes distortion (forgot to finish it)
Username: Thomas_g
NM
Post Number: 554
Bassman how do ur cvrs sound w/both tuned to 32hz? I bet songs like late night tip sound fu*kin great!
Username: Imalik
I have a Hi fonics bx 1000d I know its not the best amp but I dont think its a bad amp for the cvr's
Username: Killswitchjd
Post Number: 87
I have two cvr's, in ported boxes they only need 300 rms each... which is what my amp will be giving them, after I get my alternator in...yes they get loud with okay sound quality, and they are affordable. Ported boxes are a must
Username: Stnorris
Post Number: 82
Tj - yeah i got my subs hooked up. I need someone to help me getting the sq better though. I accidently hooked the subs up wrong and them playing for awhile. I hope that didnt mess anything up. the subs sound okay for now, but i definantly need to put sound deadner on the trunk and trunk lid!!! Then i need to keep tweaking the amp.
Does your lanzar have bass boost? if so, whats it set at, and whats the bass on your HU set at?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1187
TJ - yea, my box is tuned to 32 and it sounds great. i love my setup. lol, late night tip does slam, and so does tech nine's "t9x". they have very nice sq too, and they are plenty loud for me
Username: Reef
Post Number: 127
what would you get if you were me i dunno wat to get either CVRs or assassins i have heard great stuff about CVRs
Username: Dustin3
Tigard, Or U.S.
Post Number: 1192
toss up. they are very hard too compare. i think they are close in sq and spl.
Username: Reef
Post Number: 128
wat would you rather get
Username: Dustin3
Tigard, Or U.S.
Post Number: 1194
prob the assasin. but i do love my CVR's. lol.
Username: Reef
Post Number: 129
how much is shipping for assassins do yuo knwo
Username: Dustin3
Tigard, Or U.S.
Post Number: 1195
http://cgi.ebay.com/4-12-Ascendant-Audio-Assassins-New-DD-RE_W0QQitemZ9728212736 QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this is nice
Username: Dustin3
Tigard, Or U.S.
Post Number: 1196
i dont know from the websight. but they do have the warrenty there (3 years)
Username: Reef
Post Number: 130
i found a audiobahn amp should i ger that to power them
Username: Dustin3
Tigard, Or U.S.
Post Number: 1200
which one? intake series?
Username: Reef
Post Number: 131
yea A8000T
Username: Reloaded
Mebane, NC U.S.A
Post Number: 154
two cvr's and a JL 500/1 and in the same position you are in, with trying to find out this information for a box and all ya know.
Username: Pelona
Perris, California USA
Post Number: 1480
2 12" of the old cvrs with the black cone in a sealed box powered by an old kicker zr360 amp
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 156
i have a 12 inch assassin and it was like $12 shipping nothing too bad
Username: Makmillion
United States
Post Number: 63
I have 2-12" CVR's in a standard sealed enclosure, 1.2 C/ft per chamber. - Hifonics TX1005D amp, DEH-P860MP Head unit.
Sounds pretty good, was going to upgrade to the Hifonics TX1505D amp and use my Eclipse Titanium 15s but it's going to take awhile to build the box...
I also have the G12 grills over the CVR's
Username: Diesel71805
I've one 15" kicker L5 coming but i know the 12"kicker L5"s pound unbelievly hard.Thats why i'm upgrading. I also have a kicker 600.1 mono amp.4 gauge wire. And i also have a Eclipse cd3000 cd player.
