Username: Dellworkshop Post Number: 10 Registered: May-06
Monday, May 22, 2006 - 23:01 GMT i HAVE A C*SAT 4000 PRO, AND THE SWITCHES ARE HORRIBLE..PLS ASSIST WITH POSSIBLE GOOD QUALITY SWITCHES THAT I CAN FIND..SOMEONE SAID SADOUN IS A GOOD BRAND...PLS ASSIT THANKS ALOT...
Username: Jmontana1 Post Number: 24 Registered: Apr-06
Monday, May 22, 2006 - 23:40 GMT oops! sadoun is a name of company that sells stuff on the net! ask LK he knows everything!! idiott!
Username: Dellworkshop Post Number: 11 Registered: May-06
Monday, May 22, 2006 - 23:45 GMT WHY DO YOU HAVE TO BE LIKE THAT !!!!!!!!!!!!!!!!
Username: Letmeon Post Number: 18 Registered: Mar-06
Monday, May 22, 2006 - 23:45 GMT I have 4 x 1 ARIZA switch, mounted outside in the elements. Had no problems with it.
Username: Woofy Ontario
Post Number: 115 Registered: Feb-06
Monday, May 22, 2006 - 23:46 GMT You can buy pretty good cool sat switches for under 10bucks...or spend a 100..they will both blow if you treat them wrong. go cheap
