Can't find
Username: Master_mind
Post Number: 8
i've been play around with my receiver and reading the threads. i read u can enter codes manually for 91 and 82 but i don't see that option in the parental control to select 82 or 91. pansat 2500a clone, dish net pro lnb. i also tried got get dn change the horizontal to vertical but nothin happen an i am facing the right direction can some one help me on what to do
Username: Woofy
Ontario Canada
Post Number: 106
You have to point the dish in a different direction to get dishnet satellites 110,119
use a look angle calculator to find your elevation and azimuth.
Post Number: 9
i got all the calculations correct all i get is the dish network logo and commercial a couple of foriegn channels thats it. no movie, sports etc
Username: Woofy
Ontario Canada
Post Number: 111
In your installation menu what satellite does it say you ar receiving. if you are on 110,119 and are using the latest bin for your stb and have scanned your channels there should be no problem.
Post Number: 10
it say 110 in the sat menu and i have 274 runnin in stb thanks for the info i do another scan
