Username: Tariqic Post Number: 1 Registered: May-06
Monday, May 22, 2006 - 12:39 GMT Able to get Bell Express 91 and 82 and am facing the dish Southwest; however am unable to locate Dishnetwork satellites. Any help would be greatly appreciated. Thanx in advance.
Username: Woofy Ontario
Post Number: 95 Registered: Feb-06
Monday, May 22, 2006 - 12:42 GMT they are at a different elevation and azimuth..use a dish pointing calculator to find your settings..just do a google search for that.
Username: Tariqic Post Number: 2 Registered: May-06
Monday, May 22, 2006 - 12:55 GMT I should be able to find any of the Echostar 3, 6, 7, 1 satellites and be able to get the channels provided I lock into the right satellite and have the right bin file?
Username: Tariqic Post Number: 3 Registered: May-06
Monday, May 22, 2006 - 12:57 GMT Also, I have a Dish 500 ProPlus with Twin LNB that has one coaxal cable comin out. Do I need to put that to a switch?
Post Number: 99 Registered: Feb-06
Monday, May 22, 2006 - 13:13 GMT No the dish 500 twin lnb has a switch built in so do not use a disque switch, you will want to aim for satellites Echostar(8/10, 110, Echostar( 7)119
Username: Dellworkshop Post Number: 5 Registered: May-06
Monday, May 22, 2006 - 14:35 GMT my 110 says it is looking at 119 and so is my 61.5 all of a sudden it says that both is looking at 119..working perfectly yesterday..119 is working perfectly as always..pls advise.any help is appreciated..thanks
Username: The_wank_artist Post Number: 384 Registered: Feb-06
Monday, May 22, 2006 - 15:02 GMT check your DISEq settings. Perhaps all your settings have reverted to one port? i.e 119 = port 1 110 = port 1 61.5 = port 1
Username: Dellworkshop Post Number: 6 Registered: May-06
Monday, May 22, 2006 - 16:34 GMT i tried different ports, but it still reads 119 even 121 reads 119 ???? pls help
Post Number: 107 Registered: Feb-06
Monday, May 22, 2006 - 16:43 GMT If you were picking up 110 and 119 yesterday with no problems and you have not moved the dish or done anything else..then if you have an extra disque switch i would try replacing that..it may have failed.
Username: Dellworkshop Post Number: 7 Registered: May-06
Monday, May 22, 2006 - 16:46 GMT thanks, will have to order one.will try that. any specific brand..the one that i have came with my c*sat 4k po
Post Number: 109 Registered: Feb-06
Monday, May 22, 2006 - 16:51 GMT yea the cool sat ones are fine..i would order a few..keep and extra handy..am told they fail fairly often. least there cheap.
Username: Dellworkshop Post Number: 8 Registered: May-06
Monday, May 22, 2006 - 16:52 GMT thanks for your help.. hope all go well
Username: Tariqic Post Number: 10 Registered: May-06
Monday, May 22, 2006 - 18:24 GMT do the keys for D**H go in Niagra1 or Niagra2?
Username: The_wank_artist Post Number: 385 Registered: Feb-06
Monday, May 22, 2006 - 18:27 GMT nagra 2.
Username: Tariqic Post Number: 11 Registered: May-06
Monday, May 22, 2006 - 18:38 GMT Do I still need s switch if I have a D**H 500 ProPlus with twin LNB?
Post Number: 114 Registered: Feb-06
Monday, May 22, 2006 - 18:52 GMT If you are just picking up 110,119 then you do not need a disque switch..that has one built in.
