hi,i was wondering wat tp do fsn bay area and bet come on? also i have a dish 500 and i have one wire plugged into the diseq switch but everytime i switch from a channel from echo 7 to echo 6,8 i have to turn off the reciever to watch the echo6,8 channel any suggestions?thanks
And, if you are using a dish 500 with a twin lnb don't use a disque switch at all, they have a switch built in to them..just run one cable direct from a port on lnb to your stb.
