thanks eva & boyce but I have the keys numbers my problem is I do not have autoroll at all anywear i looked control panel can't turn it off, if you can"t find it. I never needed to turn it off before.all I did was put different keys numbers in the boxes. if you can think were it mite be I would would grafeful.
Dog: If you do not have autoroll turn off option in your receiver do you need rename the satellite. go to installation, edit tp/satellite, select satellite, rename. IF you still have problem scan all satellite and try turn off back button or disconnect. Lucky
Posted by Ikaika: Go to Menu, Parental control, second pin, enter 0000, bottom of next list, key emu, select off, go to nagravision 2, Dish net, enter keys.
N 0101 00: E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C
N 0101 01: 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC
hii,, i need some help.. whenever i try to change my nagravision to 2 the 00 and 01 become 0E and 0F,, what is the problem,,why is this happening,, does anyone know?? please inform me at soon as possible.. thankyou
ok,, now i got the 00 01 thing working,, but the keys are not working for me,, the keys that are posted here are 16 numbers each,, mine only takes 8 for each.. i have a panset 2500 reciever with the DishNetwork,, does anyone know the keys?? or what is the problem??
