Dynomat Xtreme ....
Username: Rovin
Trinidad & T...
Post Number: 7936
hey fellars u all prolly seen my ride b4 https://www.ecoustics.com/electronics/forum/car-audio/189456.html
the rearhatch door is rattling real bad & now my roof is sorta 'flapping' loudly too so i was thinking about
Dynamat Xtreme Trunk Kit
Part Number: # 19405
Contents: (5) 18" x 32" (457mm x 812mm) pieces of Dynamat Xtreme , around $110 for the kit
My ? is - will 1 layer be enough or like in the rear hatch door will i need 2 layers ?????...
Username: Extrmndor3
Chicago, Ill Us
Post Number: 828
u have to put the other one the one that look like foam that one is the best for the hatch and roof
Username: Matt12490
Benicia, California USA
Post Number: 910
anyone who speaks english?
Username: Pelona
Perris, California USA
Post Number: 1483
aw thats fuckd up matt. lol
Chicago, Ill Us
Post Number: 829
fak off nigga u only want trouble fakin punk @ss
go f@rt yourself
Chicago, Ill Us
Post Number: 830
http://www.dynamat.com/products_car_audio_dynaliner.html
thats the one im talkin about
Chicago, Ill Us
Post Number: 831
or this one right here
http://edesignaudio.com/product.php?cid=18&pid=34&cur=USD
Username: Rovin
Trinidad & T...
Post Number: 7941
yeah that dynomat roof insulator stuff looks good but im wonderin since its so thick if my roof upholstery will fit back original , will have 2 go check how its made & what space available .....
Chicago, Ill Us
Post Number: 832
yeah it will fit i got the same on a neon and the explorer i dont have it in the doors only on the roof cuz it was my major problem
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1790
well i have dynamat extreme on my doors and it makes one he11 of a difference, it doesn't vibrate, and sounds so much better, you might have to put a couple layers on though, depending on how loud your system is.
Chicago, Ill Us
Post Number: 838
i already have it the original but im too lazy
Username: Northomaha
Post Number: 71
im just gonna put this one out there, i was lookin at dynamat and stuff and it was just so damn expensive to cover my whole roof. so what i did was go to a carpet store and bought the high quality carpet pad, put it on my roof between the headliner and the roof and it works GREAT i also saved about $100. its kinda ghetto but you dont have to tell anybody
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2209
you can put the dynamat xtreme just about anywhere. it'll work fine on the roof. theres actually quite a bit of space behing the head liner.
Username: Johammbass
Cork, Cork Ireland
Post Number: 100
1 layer will be OK, but 2 will be OKer:-)
Stockbridge, GA USA
Post Number: 2211
so then 3 should be OKest?? :-)
lol
Cork, Cork Ireland
Post Number: 103
Cork, Cork Ireland
Post Number: 104
I had 3 layers on my Acura Integra doors, made them a little heavy, but it worked:-)
