Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2228 Registered: Dec-05 | http://woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3638 what do you think about this box ? |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 845 Registered: Nov-05 | It looks good. I would go cheaper for you and build one. lol. But seriously. i would do custom colors. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2229 Registered: Dec-05 | alright i will have to wait a couple weeks for some extra cash though , if you want to build one for me sounds nice |
Silver Member Username: Matt12490Benicia, California USA Post Number: 897 Registered: May-05 | it doesnt say what it is tuned to |
Bronze Member Username: One_loud_vettBelmont, NH Usa Post Number: 14 Registered: Dec-05 | D0nt waste your money on that box!!!!!!!!I have a type r powered by a rockford 700s &00rmsx1 1400 watt peak.I tryed a few boxes and I was unimpressed by all until friday I found a box built almost exacvtly to alpine specs.It was like night & day,you would have thought I added another sub.My one ten sounds better than most of my friends dual 12s.Buy the right box !I think the port is the key alpine recomends a 1"x11"x22"deep port.Trust me wow.I found that box at a local shop for $40.00. |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 850 Registered: Nov-05 | Well i'll work on designing a box and if you want IM me or email me at farrisaudio@gmail.com. MY s/n is alextf11.If you don't want me to make you one thats cool. |
Silver Member Username: Alex_fLawrenceburg, Ky Us Post Number: 852 Registered: Nov-05 | well, i take that back. I can't design a box because alpine posts none of the specs i need to make one. Sooo.... like Jesse said it would be the ported volume alpine gives. |
Bronze Member Username: One_loud_vettBelmont, NH Usa Post Number: 15 Registered: Dec-05 | The specs are on the spec sheet that came with the sub.You could always call alpine to get them if you dont have the spec sheet.Good luck |
New member Username: KrisackermannPost Number: 5 Registered: May-06 | does anyone have the specs for the type r's to make a box cause i have lost that sheet that comes with them... |
Gold Member Username: RovinTrinidad & T... Post Number: 7939 Registered: Jul-05 | OPTIMUM SEALED = 0.78CUFT OPTIMUM PORTED = 1.7CUFT ..... |
Gold Member Username: Young_jamesCanada Post Number: 1532 Registered: Sep-05 | don't say tuning, cuft size, thickness of MDF, etc. Too many factors and not enough info |
