JL 500/1 on Two CVR's ?
Username: Reloaded
Mebane, NC U.S.A
Post Number: 155
This is what I have for now, I know JL amps are expensive but I have aquired one and it works perfectly, the thing is I want to make sure will this be ok to use in this setup for now, I mean I know the rms of the subs is 400wrms but it shouldnt hurt to put a JL on it right, I mean it will sound great still right?
Username: B_son
Post Number: 21
i would think so but the subs split the 500 watts rms so each one would get 250 a piece. Seems alright but the jl 500/1 isn't the amp tht type of setup if u wanted best output of those subs
Username: B_son
Post Number: 22
what ohms are ur voice coils
i would think so but the subs split the 500 watts rms so each one would get 250 a piece. Seems alright but the jl 500/1 isn't the best amp for tht type of setup.
Username: B_son
Post Number: 23
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=360
theres a 2channel for probably have the price!
Username: Tjmutlow
Post Number: 2093
if you have dual 4 subs, you need to run series/parallel to a 4 ohm load....
Username: Reloaded
Mebane, NC U.S.A
Post Number: 156
how much should I sell the jl for then? Its $600 at the dealer so what should I ask for?
Username: Tjmutlow
Post Number: 2100
well, sorry to say, but going rate is only about 250 or so....
