4" and 6" flared ports!!!
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2960
ok...i finally got building these thing down pretty well. here are some pics of the first batch:
http://www.putfile.com/marshall_white/images
the 6" ports are flared to 8 3/8"...the black stuff on the inside of the port is from the torch i had to use to heat the pipe, i am going to have to wash it off. the scratched look on the outside is where i ground down all the burnt part where i heated the pipe (i heated the outside of the pipe).
i am building a better mold that should allow me to flare the 6" ports to ~9" :-)
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 458
sup marshall... did u finally get those amps???
Post Number: 2961
drivingreckless,
you got PM
Post Number: 459
mfebre@verizon.net
or IM me at drivingreckless
Post Number: 2962
i sent you an IM here on ecoustics.
Post Number: 460
wut do u mean????
Post Number: 2963
click the "check new messages" link about 2inches from the top of this page...on the left.
Post Number: 461
rright now wut???
Username: Terry6405
Sullivan, IN US
Post Number: 788
how r u building the mold?
is there a tutorial?
Post Number: 2964
i may put up a tutorial later on...just like i did w/ my interchangable ports thing.
i have to get my molds built first...i'm going to try to find a wood-lath to use.
Username: B101
Queen City, NC USA
Post Number: 2856
are u sellin these??
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2984
wow, those 4s look manufactured. great job! how would you go about mounting them? just glueing in place?
Post Number: 2965
ya...i'm gonna start selling them. prolly really cheap. i can start selling the 4" ones as soon as i get a few couplings.
i will sell them w/ 2 flares, 2 couplings, and a 16" center pipe.
here is a pic of a 4" flare from the first batch:
http://putfile.com/pic.php?pic=5/13823355694.jpg&s=f5
they will look even better after i get a better mold build. i'm going to try to flare the 4" ones to 6"+, the flare will be deeper too.
and ya...the best way to mount them will be to just glue them in place, you can also use screws and let the head of the screw kinda over lap the edge of the flare (dont actually screw thru the pvc):
http://putfile.com/pic.php?pic=5/13823465389.jpg&s=f5
Username: Jprix82
Post Number: 572
Hey marshall we need a tutorial :-)
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2448
so ur makin flared ports now marshall?
i would love bout 3-4 6 inch ports lol
Username: Nemen
Post Number: 817
how much you gonna charge by the way?
Post Number: 2966
i plan to keep the price as low as i can. prolly around $20+ship for a 1 peice port flared at both ends...and $20+couplings+ship for changable ones
(2 flares, 2 couplings, 1 center peice).
i just got though building one of the 6"ers flared to 9"! This thing is huge :-)...i literally dropped an 8" kicker CVR into it and it had room to spare
Also, i found a lath to use to build a better mold...and i'm goning to buy a few hi-powered heat guns so i wont have to use a torch on the 6" anymore. I should be able to build them pretty quick when i get everything set up the way i want it.
so....who wants 6" flares? :-)
Username: 54danny54
Post Number: 2456
here in a bit i would like 3 of em...
lol how bout shaving off 5 bux a port
Post Number: 2967
I'll see what i can do...if i have to buy the same pipe i used on those ports (SDR-35) i will prolly stick to $20+couplings+ship. But if i can find some thinner walled (cheaper) 6" pipe locally, i'll try to cut the price.
10ft of 6" SDR-35 costs me $35+ :-(
i just want to make a few buck on this...just enough to pay for the heat guns i'm gonn have to buy...lol.
The torch blackens them too much....i have to spend too much time grinding off the black stuff...plus it makes them look less then pretty, lol.
i have to go buy some more pipe monday.
Username: 54danny54
Post Number: 2459
i might want 1 9 inch port lol.
that would be so tight
Post Number: 2970
What i mean is that i flared the 6" pipe to 9".
I'll post pics of it tonite.
