Bev Keys
Username: Brucelee
Beverly Hills, California United States
Hi there,
I have the new bin on VIEWSAT with autoroll and all. For some reason all the BEV channels are blank? I tried to update the code for BEV but without any prevail. Does anyone know if there are newer codes or if there is something else I need to do?
Thanks
Username: Woofy
Ontario Canada
Post Number: 117
You don't need to do anything..bev has sent down counter measures..all are in the same boat until coders fix..aim to dish..all is well there right now.
Username: Brucelee
So does that mean that I have to wait until the fix goes through?
Since I'm getting blank channels?
Thanks
Username: Brucelee
Post Number: 7
Is there any temporary work around? Can I go back to bin v1010 for my Viewsat and hope that the Bev channels would work, or is it something that they have to fix? I currently have v1072 on my VIEWSAT (Platinum).
Thanks
Username: Woofy
Ontario Canada
Post Number: 120
your out of luck for now..bev only works on plastic at the moment. like i said you could re aim your dish to 110,119 dishnet is still working fine right now.
Username: Top_g
I have been on BEV for about 2 weeks and want to switch to DN till the problems are resolved. I need help pointing my dish though. to get BEV i point my dish South. Where is DN? I live in western Ohio.
Username: The_wank_artist
Post Number: 393
BEV was 91 degrees.
DN are 110 or 119 (for the most part though there are otheres). you need to go 19 or 28 west, depending on which one you want.
Username: Woofy
Ontario Canada
Post Number: 121
If you want you can go to this link below and put in your zip code..it will give you the proper look angles.
add a w for the link to work.
http://ww.dishnetwork.com/content/products/installation/azimuth/index.shtml
Username: Brucelee
Post Number: 8
Hi there,
thanks for the responses. I actually have two other dishes pointing to Echo 6,8 and have another pointing to Echo 9 (121W). I just didn't know what was going on with BEV with my other two dishes. I guess I'm going to have to wait it out. Too bad because there were cricket matches that were on BEV only.
