DP301 with HD
Username: Latinboy2006
Hi Guys,
I'm going to buy a new HD TV (LCD or Plasma) but my question is:
Can Dish Pro 301 be a HD compatible? or I have to change to another model of Dish?
Also Pansat 2700 will be HD Compatible?
I mean these could be HD receivers?, that's why I want to buy a HD TV...
Thanks for any Suggestions!
MR
Username: Wnyzfinest
Post Number: 24
You Wont Get HD Quality, mostly a Simulation.. Pansat 2700 doesn't use composite wires (red, blue, yellow, green etc)
also depends which sats you are tapping into,,I would recomend the 3lnb superdish, Go on the HD Sat, and 110/119sats .. On A Pansat I would Say 6000 series..
Thanks Danny, I think I have to upgrade for a better pansat, or try with dish 301 with a simulation... but I think it will see better than my old TV ;O)
Username: Nyckl
Jasper, Texas USA
301 is def. not HD compat...i install dish network allll day long...lol...and boy is it hot here in east texas...a 301 will work with the HD programming...but it will not be in high def...
