Bronze Member Username: Aman2005Post Number: 50 Registered: May-06 | Want to know that upgrading a car's electrical system for running a 2000 w rms amp makes any ill effect on the car's performance in any way or not? I've a Skoda Octavia http://skoda-auto.co.in/rtdi |
Bronze Member Username: Aman2005Post Number: 51 Registered: May-06 | Sorry the URL is http://skoda-auto.co.in/ritdi |
Silver Member Username: CtmikeCt. Post Number: 620 Registered: Feb-06 | the links didn't work for me. but find out how big the alt. is in your car first. not exactly sure the exact size you'd need, but get a ho alt. that's about 190 amps or higher and you should be set. i'd replace the battery to while you're at it. if you don't replace the alt. with one that will support all the extra requirements from you audio equip. it'll just be a matter of time until you're car dies, the amp, subs, so on. read this http://wickedcases.com/caraudio/charging.html |
Gold Member Username: Young_jamesCanada Post Number: 1523 Registered: Sep-05 | ^^^What he said |
