Speaker wire
Username: Troy81
Tavernier, Fl Us
Post Number: 225
would geting bigger speaker wire make any difference in the amount of watts runnng?
i checked the ohms at where the wire plug into my amp(the wire unplugged from the amp) and it was 1.5 so im guessing that means im not losing any in the wire, im running radioshack cheapo wire, and im lookin for sound so any help would be nice thanks.i would guess its about 16 gauge
Username: Rovin
Trinidad & T...
Post Number: 7952
http://www.wickedcases.com/caraudio/wire.html ....
Username: Sw9152
Michigan
Post Number: 710
16 gauge should be plenty big. look more into the power wire and upgrading the alt for more sound. also the box is a big part of how your sub will sound and even which way it is pointed can effect the sound.
