Can I connect two 15" subs to i channel amp?
Username: Toyotagurl
DeBerry, Texas US
I was wondering if I can connect two 15" subs to a mono channel amp? It only has a connection for 1 sub, but can I do a crossover?
Username: Johammbass
Cork, Cork Ireland
Post Number: 87
Yes you can, but the thing is you have to do it right and know if the amp has enough power to push two of those subs
DeBerry, Texas US
Thanx Maris!!! It is an 800 watt amp and the 2 subs are 500 each!
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2190
that depends on the VC configuration of the subs. that will determine the load you put on the amp, which will affect the amp's output. lower the impedance, higher the output, higher the impedance, lower the output. but you have to stay within the amp's limitations. most can't go below 2 ohms.
Username: B_son
Post Number: 33
heres the wiring diagram
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC4x2
Username: B_son
Post Number: 34
or...
amp must be 1 ohm stable though
