Silver Member Username: Reloaded
Mebane,
NC
U.S.A
Post Number: 151 Registered: Dec-05
Posted on What should my cuft. be per chamber? |
Silver Member Username: Thomas_g
NM
Post Number: 571 Registered: Oct-05
Posted on I put 2.20 cuft per chamber for mine. |
Mebane,
NC
U.S.A
Post Number: 152 Registered: Dec-05
Posted on hows that sound? and also I am trying to put a JL 500/1 on two of the CVR's will this work? |
Mebane,
NC
U.S.A
Post Number: 153 Registered: Dec-05
Posted on but that would be a vented enclosure wouldnt it? if I give it the minimum 1 cuft per chamber would I still get the bass I want with sq as well? |
